SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
SOURCE: Washable filter clogging
They have bad seals that allow to much dirt to get through, order new cyclone assy $80.00 it will be fixed on model dc17 very big problem
SOURCE: Motor overheating
There is a filter on top of the motor as well. You will need to remove the plastic cover on top of the motor with a small screwdriver or other flat blade. On the front, you push in the clip and pull up ont he cover. On each side of the cover there is another clip - to pop those you put your flat blade into the angled tab and slide it around to the clip until it pops. Gently or you'll break the tab. Once the cover is off there is a purple tab in the center pull up and you will pull the HEPA motor filter out - similar in shape and size to the side, washable, filters. Clean or replace that.
SOURCE: DC07 ANIMAL PURPLE WASHABE FILTER
Immediately above the right wheel (looking at the machine from the front) there is a short length of curved pipe. Lift this pipe upwards, with a slight forward rotation, and the filter housing will come out with it. Be sure to follow instructions for washing the filter, and especially for drying it before putting it back. If you put it back when even slightly damp you risk turning it into a solid lump and you'll have to buy a new one - you'll also get the motor damp, which is a generally bad idea!
Good luck. If you need more help, lust ask!
SOURCE: hair on top of washable filter on d14 animal
One way or another, dirty air is by-passing the cyclone. Check that all the seals are undamaged and in place, especially the big black ring at the bottom of the yellow bit inside the clear bin. Also check that the bin base closes tight after you've emptied it.
If this doesn't help, please post a response and I'll try again. If it does help, please remember to rate me!
