SOURCE: Phillips 1TB HDD problem, playing movies hrough DVD player (USB)
My question would be are the movies in the right format. Just because they play on your computer does not mean they will play on you DVD.NTFS or FAT 32 would have no bearing on this. They are simply data per sector protocols and are related to magnetic storage devices.You may need the proper codec for you computer so it can make a DVD you player can play.
SOURCE: how do I delete files stored on the HDD of my JVC DR-MH30S?
Use edit on you remote. this will bring up delete
SOURCE: Can't see Sumvision Cyclone HDD on PC
see this link
http://docs.google.com/Doc?id=dgcfqncj_0cnqvx5gt
SOURCE: Formatting a Samsung MP0804H IDE extrernal HDD from NTFS to FAT32
Hi there Dave, well you can use a software called Partition Magic 8 to convert your 80GB hard disk to utilise FAT32. This software is quite user friendly. There are several options for you to choose form in this software including resizing your drive and creating partitions on the fly. However some settings requites a computer restart or reboot in order to complete successfully. This software can be obtained from most software stores or even download form the internet. After installing the software and running it, your drive should show inside the programme; right click on the drive you want to change a setting and select the options available. At the 'Format' button select FAT32. You will be asked for drive letters and cluster size but you can use the default settings, then apply the settings. Once you are done with that select the Okay button in the main programme window and the formatting process will start. Hope this helped you. Cheers :-)
SOURCE: Hello, Ive bought a LG RH387H
The manual does not specify the usb size max.
I would expect not more than 8 GB to 32 GB max
Also remember fat 32 cannot support large file sizes more than 8gb
