SOURCE: Coffee grounds in pot
maybe you grind or buy coffee that is to fine it take longer time for water to go true the fine coffee differente coffee different grind cheers
SOURCE: GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
SOURCE: I need Cleaning Instructions for my HDX23 coffee maker
Find that at http://manualfox.com/link/oster.htm
SOURCE: Filter basket overflows after cleaning Bunn VPR Coffee Maker
Some people also try adding fresh grounds to brewed grounds, resulting in an overflow. A restricter valve can be used, but a better solution is to simply pour in half the water at a time. This is what people who buy non Bunn filters do to stop overfills.
