Question about Razor Toys
Replace ecosmart scooter rear wheel
Razor ecosmart scooter tire
  • 766 Answers
Posted on Mar 23, 2019
SOURCE:
honeymokey
  • 3113 Answers
SOURCE: how do i replace a wheel bolt from a 2005 dodge
Remove wheel and beat it out with a hammer. Put new stud in and replace wheel and tighten and it should pull through.
Posted on Jun 13, 2009
  • 38 Answers
SOURCE: Bought a razor pocket mod scooter second-hand-it
Use a wedge. Place the thin end between the tire and rim. Then push the tire off using the wedge and your other hand, work your way around the circumference of the tire until it is off. Use the same process to put the new tire on. But this time you will push the tire on the rim.
This is a pic of the ideal tool you should use:
Posted on Aug 13, 2010
  • 38 Answers
SOURCE: I need instructions on how to replace the rear
You can't change the tire it is a soild rubber tire molded to the rim. To replace it you have to buy a new rear wheel. Here is a website that sells it.
http://electricscooterparts.com/razore100.html
Posted on Aug 18, 2010
  • 38 Answers
SOURCE: re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Ironfist109
  • 3018 Answers
SOURCE: how to remove rear tyre from e300 electric razor
  1. With a Phillips screwdriver loosen the two screws and remove the chain guard.
  2. With a 10mm wrench loosen the brake cable anchor and disconnect the cable.
  3. With two 8mm wrenches loosen the brake housing anchor and disconnect. (Keep the spacer and washers together.)
  4. With a 10mm wrench loosen both axle adjusters an equal amount. (roughly five turns)
  5. With two 17mm wrenches loosen the axle.
  6. Push the wheel forward in the slots to loosen the chain.
  7. Pull the wheel out. (Pay careful attention to the order the hardware is in there.)
Regards, Tomy
Posted on May 01, 2011
Testimonial: " that tells me how to remove the weel but not the tyre but thank you anyhow "
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
How to fix my razor scooter e100?
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
Aug 13, 2014 | Sport & Outdoor - Others
How to put air in tire of e300 razor
  1. rotate the rear wheel until the hole in the sprocket lines up with the tyre valve.
  2. insert the tyre valve extension through the hole and attach it to the tyre valve
  3. inflate the tyre to the correct pressure (usually 45psi)
  4. remove valve extension and put in a safe place for next time.
Inflating the rear tyre is detailed in the owners manual, which you can download from the Razor web site.
http://www.razor.com/au/products/electric-scooters/e300/
Jun 25, 2014 | Razor E300 Scooter
When i push the thumb control down the motor comes on and the chain turns but the rear tire does not what is causing this? thank you
If the sprocket and chain turn on the rear wheel, it sounds like the freewheel on the rear tire is faulty.
Sep 28, 2010 | Razor E300 Scooter
How do you get the tyre of the rear wheel off a razor 300
Its not meant to be removed. Purchase a new one and save yourself some troubles. You need special tools to remove it. I highly recommend purchasing the wheel complete.
Sep 12, 2010 | Razor E300 Scooter
I need instructions on how to replace the rear tire on a razor electric scooter model E100
Jul 27, 2010 | Razor E100 Electric Scooter
Re-assembling a E200 rear wheel
Jun 28, 2010 | Razor E100, E125 & E200 Electric Scooter...
How can I put chain back on my E200 razor electric scooter?Everything is in the way.
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
Apr 24, 2010 | Razor E200/300 Electric Scooter Battery
Toys Logo
69 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
