Computers & Internet Logo
Anas Melli Posted on Mar 23, 2019
Please can you send me data sheet for the following: 1- transistor RBL 69 2- TRANSISTOR 43P THANK YOU
2helpful
4answers
I forgot my password for my gmail account. [email protected]
1. click on need help option below the sign in button
2. click on the forgot password option
3. enter the email id of which you forgot password
4. now choose from the recovery option either recover by email address or phone number and follow the steps
I NEED DIAGRAM OF CONSTRUCTION FOR REGULATOR P5NK50ZFP
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
HOW TO TRANSFER TALLY ACCOUNTS DATA TO EXEL SHEET
HI,
Please follow below step
Step 1. Open Tally
Step 2. Open Report Which is you want Transfer in Excel.
Step 3. Press CTRL With E (Ctrl+e) from keyboad
Step 4. Select Sharped Sheet or Excel
Step 5. After type location for file save like this D:/your folder name/
Step 6. After You type file name with xls. like this sales.xls
thanking you
davevipul197
2helpful
2answers
1992 Rockford Fosgate Power 100HD transistors ss256s and ss257s data sheets or substitutions
they are gone gone long gone there is no information about it
i remember 15 years ago having the same problem with the 100 hd and the 75 hd
call fosgate they fax me the schematic showing the modification
how to use different transistors and a new resistor have to be replace for each transistor
good luck
save that amplifier i have mine in the close-tt
What transistor would be the replacement for the small transistor in my alpine mpr-m1000 called D600k Y 834? Where could I get it and what would it be called?
The transistor is LIKELY a 2SD600 which google brings up data sheets for you.
It is an Epitaxial NPN 100/120 volt 1 amp transistor, but do check the datasheet for verification.
A lot of these units seem to drop the 2S prefix of the Japanese labels.
Trace a lttle of the circuit and verify the 2SD600 makes sense.
VLOOKUP FORMULA PROBLEM
VLOOKUP(A1,Sheet2A2:B20,2,FALSE)
The assumption here is A1 in Sheet 1 is the cell you want to reference, This cell can be pasted - Any problems let me know.
3answers
LTV-3001
Check this data sheet. You will find the type of part Q12 is.
Excel Sort Across Sheets
Hi Raymond, I have a solution for you. Asuming your 'main' sheet is Sheet1. On Sheet2, in the same line as your data on sheet1 (i.e. A5 on sheet1 is JIM), then on A5 on sheet2, enter a link ( the = ) and enter. copy this formula down. Do the same with Sheet3 linking to Sheet1. When you sort Sheet1, Sheet 2 and 3 will follow. Hope this helps. Regards DeltaC
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
