Check belt if ok check motor also check drain hose and pump
SOURCE: Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
SOURCE: spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
SOURCE: whilpool washer #LLR6233ANO
The symptoms you are describing are usually caused by a lid switch malfunction. A lid switch is a very simple and inexpensive fix. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms.
If the model number you have this listed under is correct, you can find replacement parts at searspartsdirect.com. Just type in the the model number and you can locate what you need under the "Top and Cabinet" heading. The lid switch is item number 9 (part #285671) and the lid strike is item number 20 (part #358684).
I hope you find this information helpful. The total cost of your repair is less than $50 if you follow the instructions in the link I provided and repair it yourself. Let me know if you require additional assistance.
SOURCE: Washer will not spin
My mum had this problem. I think it had something to do with the barrel coming loose.. - get a plummer ;)
