I don't know if the HP Office Jet 5200 printer control panel is a touch screen. I want scan my documents to a Mac computer. Do I need a manual / driver?
SOURCE: regarding hp office jet 4110 printer driver
get it here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90792&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20â»
there are three models
HP Officejet 4110 All-in-One Printer
» HP Officejet 4110v All-in-One Printer
» HP Officejet 4110xi All-in-One Printer
do check which is yours and download...hope it helps!
SOURCE: HP OFFICEJET 5610V No scan options
If you get the error while trying to scan with your HP 5610v All-In-One, the easy way to scan from your printer is to click on start, go to Paint and then File, the option "From Scanner or Camera" will come up.. click there and poof - you can scan anything you want and save it where you want... Problem solved!! good luck!!!
SOURCE: Need software to install HP OfficeJet T45 printer to my Vista PC
I had the same problem, but was able to use my printer by adding HP OfficeJet V40 instead from the dropdown list. I didn't need to bring in a driver. Try it...it worked for me.
SOURCE: HP4550 No Scan Options: Refer to Device Documentation
Double click the icon on your desktop called hp direc tor/hp solution centre.
point to settings and the point to scan settings.
click on the option that says scan to setup.
a new window will open with a list (called the destinations list).
select each item on the left hand side and then there will be a right arrow button click on that.
Once your done with all items then at the bottom of the new window there should be either an ok/update the device button now try to scan this should now work.God Bless
This is a free Mac OS X driver installer package for the HP Officejet 4500 wireless all-in-one printer.
Enjoy the convenience of wireless connectivity with the Officejet 4500 wireless all-in-one printer. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with tje Officejet inks, you'll get professional-quality color printing at a low cost per page.
http://mac.softpedia.com/get/Drivers/HP-Officejet-4500-Driver.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
