Hello Bob, no, your Sony CDP-CX200 is not ready to play MP3 CD
The MP3 began to be used in 1995 and your Sony
CDP-CX200 is development of the year 1996, they had not yet incorporated the MP3 format
I enclose the user manual where it describes the CD formats that it reproduces
Greetings Franco Dosil
Hola Bob, no, tu Sony CDP-CX200 no esta preparado para reproducir CD MP3
El MP3 comenzo a utilzarse el a?o 1995 y tu Sony
CDP-CX200 es desarrollo del a?o 1996, todavia no habian incorporado el formato MP3
Te adjunto el manual de usuario donde describe los formatos de CD que reproduce
Saludos Franco Dosil
https://www.manualslib.com/manual/610565/Sony-Cdp-Cx200.html
SOURCE: Sony CDP-XA30ES CD Player
Try opening up the top and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, look at the back side of the optics and there should be a marking like KSS-xxx. This is the generic part designation. Any electronics supplier that supports Sony should have these.
Dan
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
SOURCE: sony cdp-c545 won't open
Without turning the unit upside down, look at the bottom of the player. You should see a small round hole toward the front of the unit, with a white plastic part inside with a slot. Take a screwdriver and turn this gear manually with the power off. You should be able to unload the discs by rotating this gear. Be careful not to tilt the unit, as the discs will fall out of the tray, and you'll have to open it to retrieve them.
Once you have the discs out, put in only one disc and see if the unit plays. If you get a disc error, you probably need to clean the lens on the laser. Open the unit, use a cotton swab that has been pre-wetted with glass cleaner to wipe the lens on the laser. Do this gently, don't press down hard on the lens. Use the other end of the swab to dry the lens. Try loading a disc with the top cover off and see if it spins. If it doesn't spin, try turning it by hand. If you can't turn it by hand, the gears have gotten out of alignment.
In this case, use your screwdriver again, noting which way the gear on the bottom of the unit spins when the drawer is going into the unit. Then turn the gear until it "pops" past one or two teeth, and then you should see the laser assembly rise up and meet the clamp assembly on the top of the tray. These are the most common problems with the 5 disc players that Sony made. Many times I could fix them in 30 seconds or less using this procedure.
SOURCE: Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Before you dive in and possibly wreck it, read this...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-CDP-CE375-CD-Players-manual/id/423ci261/t/2/
It does not read MP3's in any format. Media abilities do not imply file abilities.
It's your mom
