Salter 1052 Manual - in case it has similar features.
http://www.scalemanuals.com/saltermanuals/1052-manual.pdf
SOURCE: I have lost my instructions
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
SOURCE: I own the Salter Stainless steel electronic
yes. here is the link to the company http://salter-scales.com/ just click on the link and then enter your country. then you will see a place for parts or to contact them.
Testimonial: "Thank you! Wow, didn't expect a reply so quickly. Appreciate your help."
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
