SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
SOURCE: Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
<?php
if(!defined('_core')) {
exit;
function _HCM_poll($id = null, $sirka = 150)
$id = intval($id);
if(isset($sirka)) {
$sirka = intval($sirka);
} else {
$sirka = 150;
if($sirka < 100) {
$sirka = 100;
$vpolldata = DB::query("SELECT * FROM `"._mysql_prefix."-polls` WHERE id=".$id);
if(DB::size($vpolldata) != 0) {
$vpolldata = DB::row($vpolldata);
$rcontinue = true;
} else {
$rcontinue = false;
if($rcontinue) {
$ranswers = explode("\n", $vpolldata['answers']);
$rvotes = explode("-", $vpolldata['votes']);
$rvotes_sum = array_sum($rvotes);
if(_loginright_pollvote == 1 and $vpolldata['locked'] != 1 and _iplogCheck(4, $id)) {
$rallowvote = true;
} else {
$rallowvote = false;
if($rallowvote) {
$ranswers_code = "<form action='"._indexroot."remote/hcm/pvote.php?_return=".urlencode(_indexOutput_url."#hcm_poll_".$GLOBALS['__hcm_uid'])."' method='post'>\n<input type='hidden' name='pid' value='".$vpolldata['id']."' />";
} else {
$ranswers_code = "";
$ranswer_id = 0;
foreach($ranswers as $item) {
if($rvotes_sum != 0 and $rvotes[$ranswer_id] != 0) {
$rpercent = $rvotes[$ranswer_id] / $rvotes_sum;
$rbarwidth = round($rpercent * ($sirka - _template_votebarwidthreduction));
} else {
$rpercent = 0;
$rbarwidth = 1;
if($rallowvote) {
$item = "<label><input type='radio' name='option' value='".$ranswer_id."' /> ".$item." [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]</label>";
} else {
$item .= " [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]";
$ranswers_code .= "<div class='poll-answer'>".$item."<div style='width:".$rbarwidth."px;'></div></div>\n";
$ranswer_id++;
$ranswers_code .= "<div class='poll-answer'>";
if($rallowvote) {
$ranswers_code .= "<input type='submit' value='".$GLOBALS['_lang']['hcm.poll.vote']."' class='votebutton' />";
$ranswers_code .= $GLOBALS['_lang']['hcm.poll.votes'].": ".$rvotes_sum."</div>";
if($rallowvote) {
$ranswers_code .= "</form>\n";
return "
<div class='anchor'><a name='hcm_poll_".$GLOBALS['__hcm_uid']."'></a></div>
<div class='poll' style='width:".$sirka."px;'>
<div class='poll-content'>
<div class='poll-question'>
".$vpolldata['question']."
".(($vpolldata['locked'] == 1) ? "<div>(".$GLOBALS['_lang']['hcm.poll.locked'].")</div>" : '')."
</div>
".$ranswers_code."
</div>
</div>\n
SOURCE: Bunn Coffee Maker Leaks out the bottom
I have an older BUNN B10 pour-o-matic that I thought was leaking from the bottom. Upon close inspection, I found that it was leaking from the worn out washers located on the top of the tank, allowing water to run down the sides of the stainless steel tank. There's a great fix offered on Fixya.com that suggests going to a hardware store and buying a Gardner Bender GHG-1575 rubber grommet with a 3/4" hole and install it into the large hole in the basin. Then place a metal washer on top of the grommet and snug it up with the threaded fitting. Many folks say it's a great fix. I went a different route. I called BUNN customer service and spoke to a very nice woman who understood my needs and sent out a free repair kit that contained a new fitting, washer, and seal. I received it in a few days and it's working great. Beats going out and buying parts for a work around repair. BTW, the repair kit is called "Universal Retail Seal Replacement Kit #37091.0000"
