It keeps saying no bootable devices
Not bootable devices.
1: the HDD is dead, or OS on it dead or both
2: no PC stated but at 7 years old the RTC coin cell is dead.
3: is this a laptop if yes, test the PC with no big battery in it, only on the AC pack running, old batteries of any kind here are no good.
the #1 failure on all PCs is batteries, many parts inside last 50 years, but never do batteries, some go 1year and die.
a hard cold fact of life, few know.
Your computer's BIOS battery is probably dead which is why it does not remember the settings from the BIOS. Simply by replacing the battery you should be good.
SOURCE: computer cannot save bios settings,
1.) open your compuer
2.) remove the battery , its a round silver thing
3.) BUY A NEW ONE , IT DEAD
replae it and you'll be fine
SOURCE: BIOS settings to boot from bootable USB Key
Hello
Here is a link for your motharboard manual
ftp://download.intel.com/design/motherbd/mv/A6514501.pdf
Your needs are in page 113
AYADI
SOURCE: no bootable device--strike f1(please help)bios wont read cd or hd
I think your lap top fails to detect your hard disk. Enter Bios settings and confirm that the hard disk is detected.
SOURCE: Acer Aspire One AOD150 Won't Boot
The netbook is trying to find a bootable device. It cannot read the hard drive, so it started looking for a network hard drive to boot from, since it did not find that it continued down the line until it asked if you wanted to go to recovery. Most likely you have lost your hard drive and the netbook is simply trying to find the next boot device.
SOURCE: bios problem i m getting in error windows loading
Typically to enter setup you only need to tap either F2 or the Delete key as soon as you turn the computer on. The splash screen will usually tell you which is the correct key. It may be called 'setup', 'BIOS' or 'BIOS Setup'.
Hope this helps,
www.PuterCare.com
Make sure the battery has plenty charge or remove the battery for a while, about 5 minutes to see if that restores it some motherboards cmos batteries are soldered in
You could check the site for the machine vendor to see if there is a reset jumper.
If that doesn't work then you will need to refresh the BIOS
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS.
To do that you need to press a key while the computer is booting Usually the Delete or F2 but can be other keys
It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one.
You will also need to reset the time and date.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Press F10 Save, Exit and re-boot and everything should then work
hope this helps
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
hope this helps you
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
hope this helps you
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
don't forget to vote
