SOURCE: My Screen!!!
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
SOURCE: samsung lnt4069f
Take out incomming signal input,recheck.Put input back,same problems.Than ur Main Tuner Signal board is the cause.
SOURCE: Bottom screen on ds lite flickers
check the cable first it might not be in the ribbon connecter properly, if everything looks ok chances are youll need to replace the screen.
SOURCE: Asus AL2216W top half screen got darker. Lamp problem ?
When the lamps are bad, the screen will shut down if the inverter cricuits is sensing open (lamps will not fire up and conduct, or lamps are drawing too much current). You should open it up and inspect the caps in the power supply first, lamps in this monitor are ntoeasy to replace (screnn will to be complete,ey disassembled.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Testimonial: "Thanks for the quick answer will try to check the caps and not bother with the lamp"
SOURCE: bottom half of screen black-out
I would replace the lower Y buffer. Part number 996500032640. Goodluck.
