SOURCE: Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
SOURCE: FORGOT HOW TO RESET INK LEVEL INDICATORS AFTER NEW REFILL
http://www.abacus24-7.com/installdell.htm Here is a is a link to a page with detailed instructions on how to reset the ink levels for your printer.hope this helps you out . biigg53566
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
SOURCE: I just refilled my HP6500 ink cartridge 920. The
There is no way to reset the ink levels on this cartridge type yet. Any replacement chips on the internet are violating patent law. Once the chip tells the printer it is empty it will not print no matter how much ink is left in it. There is always a lag time between the introduction of a new cartridge type and the ability to fill it properly. For refills I would recommend Cartridge World when this cartridge type can be refilled.
