SOURCE: receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
SOURCE: M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
SOURCE: Norstar m7310 needs rls button pushed after every call
I've seen this many times; Check the Handset cable. It is probably plugged into the Headset connection on the phone.
SOURCE: Norstar M7310 phone doesn't ring and doesn't pick up calls
You can look at the manual here:
http://www.fixya.com/support/p98000-norstar_m7310_corded_phone_nt8b21ac03/manual-34096/page-3
SOURCE: pick up line ringing Dterm 80
Line ringing preference on our NEC phone
Do not get outside line, just press:
#7579 to turn on, #7576 to turn of
Then press SPKR to exit
