I have a Ikey-audio RM3 and though on the screen it shows that it is recording the green lines are not showing on playback there is no sound though it shows up as a file with the time.
SOURCE:
SOURCE: Samsung 800x Digital Zoom Mini DV Digital-Cam
try a cleaning cassette.. if it dont work it is the heads that are bad.. try a good one.. sometimes this happens if u use old mini dv tapes.. try new.. hope this helps ya
Posted on May 30, 2008
SOURCE: No sound from LG HDD DVD recorder
Same Problem here, have not done anything yet, but I am convinced that it is due to blown Capacitors in the Power Supply......
Posted on Oct 11, 2008
  • 79 Answers
SOURCE: static when trying to record or play back audio
This cannot be windows, this has to be a lead problem to your speakers or the speakers are damaged.
Posted on Jan 25, 2009
  • 374 Answers
SOURCE: Dish Network DVR 625 Problem with playback of recorded shows
It sounds as though the hard drive is about to go south on you soon and the receiver is going to need to be replaced however, in the interim you can change the options of the recordings and make it a default so that the recording continues past the end of the show. It is possible that extending this time will allow you to view the portion you want before it skips to the end. In order to do this press the guide button and select a program in the future. On the create timer screen select the option icon. You will now be at the timer options screen you can extend the time the recording will last after the end of the show and when it will begin recording prior to the show. I would also set this as your systems default so that it performs the same way regardless of what you are recording. According to the latest known receiver issues this is not identified as it is a common indication that the hard drive has an error internally. If this works I suggest that you have a replacement sent to you so that you do not lose the use of your DVR un-expectantly.Remember to watch all recorded events prior to replacement as you will lose that info when the receiver is swapped. Thanks for using Fix Ya.
Posted on Mar 10, 2009
SOURCE: Screen isfull of colored lines. Record and play
I looked into to this it is the ccd and Canon will fix it for free (shipping included), as stated below. I have copied what has helped me!
It has recently come to our attention that the vendor-supplied CCD image sensor used in this Canon digital camera may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all. While reports of this malfunction have been rare in the United States, we have determined that it may occur if the product is exposed to hot and humid environments.
Effective immediately, and regardless of warranty status, Canon will repair, free of charge, products exhibiting the above-mentioned malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com
Posted on Mar 14, 2009
Ikey RM3 MP3 Recorder. Does anyone have or know where to get firmware download Version 1.0.40 for this recorder?
I think your unit is in "agc" mode. (not covered in the manual) Look for the letters AGC (very small) in the display. You can toggle in and out of this mode with the rec and stop keys although I forget the press sequence off hand. This will take it back to the mode it was in when you bought it.
Sep 22, 2014 | iKey Audio RM3 Rack Mountable Digital...
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Sharp MD MS 702 shows sound is being recorded but on playback shows blank disc, what could be the problem?
That does not sound good. Being optimistic, though, what happens if you record something and then finalize it? Will it play then?
Will it play a previously recorded MD?
Feb 09, 2013 | Sharp MD-MS702 Personal MiniDisc Player
Hi,I'm having a very big problem.In the Sound and Audio Device it is said that there's No audio Device !.Even though days before, i was having sound.In the Audio tab,in the MIDI music playback there's...
Ok, if you have the audio driver installer with you then it's fine, otherwise download it from your PC manufacturer's site for your model no. Run the installer, it will extract some files in C drive in a folder. now open device manager, right click on audio controller and select update option, then select install manually and "i will choose driver". In the next dialogue, click 'browse' and point it to the folder where driver has extracted files, inside the folder somewhere there will be a .inf file, select that and click OK.
If you are still having difficulty, then post here your model no., audio device etc. in detail, then i can guide you better.
Dec 10, 2010 | Microsoft Windows XP Professional
When transferring (or watching) video from this Sony DCR-TRV530
Sounds video head is dirty / clogged.
Use good quality video-8 head cleaning tape for head cleaning in DCR-TRV530 and then record and playback it.
Aug 23, 2009 | Sony Handycam DCR-TRV530 Digital Camcorder
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Jun 05, 2008 | Lexicon Lambda Usb Desktop Recording...
Soundcard
I have found that sometimes this can be interference from your line input. If you don't use the hardware that is plugged into it(if any) when recording TV shows, then mute it in your sound card volume settings
Jan 15, 2008 | Genius Soundmaker Value 5.1
 Grubhead
Grubhead
Marvin
Marvin
