Ive no idea your plan or purpose, nor history.
no PC stated
no OS stated, is this windows XP you are asking about safe mode.
well safe mode turns off by itself if you get rid of the errors first.
or if booted, go in to (runbox) msconfig.
click boot tab
turn off safe boot.
not telling at least your OS version makes any answers vastly more hard, w10 is totally different.
SOURCE: lenovo y510 wont start in normal mode (xp)
For the Lenovo to to start in the safe and networking mode, and then not have a display when you attempt to boot it in normal mode, I would follo the these steps:
Boot in networking mode, and then go to the Lenovo site and download the most current display drivers. Since you are able to operate as described above, I would start here first. Once you have successfully downloaded the most current drivers for the video on your system, BEFORE you leave the Lenovo site, check your system against the listed bios upgrades. I believe you may find you need to upgrade your system firmware. If so....download the upgrades you need, and finish the display drivers updates as discussed above, and keep the fresh firmware updates set aside and see if the display driver updates allow you to boot normally.
If so, once you have a normal boot, backup your systems RIGHT away! The next step is to then carefully read the docs about how to update the firmware. Sometimes this will require a floppy drive, if so, you can most likely either pick up a USB one very cheaply or perhaps borrow one. At any rate, make sure your system is backed up fully, and preferable with a restore point, (if you are able with XP?)
Try these measures, if it is successful I would love to hear that from you by way of a testimonial. If you are not - please return here for further assistance. I have additional help for you - but I do not think at this time you have a hardware problem.
Have a great day!!
SOURCE: how do i boot a lenovo Z61t in 'safe mode'?...
Once you turn on the computer keep on tapping the F8 key and this will give you an option to boot to safe mode.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: Lenovo stuck on loading page, and wont enter safe mode
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
