Televison & Video Logo
Natalya Baker Posted on Mar 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a onn tv and the channel is stuck on the usb photo mode .i dont have a remote , how do i change it to the menu so i could watch my cable channels?
Stoney Thompson
Level 3:
  • Master 440 Answers
  • Posted on Mar 22, 2019
Stoney Thompson
Master
Level 3:
Answers
440
Questions
Helped
145654
Points
1387
When you turn the tv on continuously push the input/menu button. Really fast. The tv will only acknowledge your pressing it when you turn it on as its starting up. Thats the only way i have found to get our of pic mode without a remote
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Dec 30, 2007
SOURCE: RCA T19064 - HOW TO GET TO MENU
i have the same set i used a rca universal remote rcr311w i think its the oem one i bought two of them at walmart i don,t know if they still carry them
Anonymous
  • Posted on Apr 05, 2008
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Anonymous
  • Posted on May 25, 2008
SOURCE: Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
A
Anonymous
  • Posted on Aug 06, 2008
SOURCE: the universal remote does not bring up the menu
If You have a cable box. Program your Tv to it and use the set up or menu button yo program it.
Anonymous
  • Posted on Aug 21, 2008
SOURCE: video mode
I went to add/delete channels in my menu on my symphonic and it let me scroll through the channels, make sure you have them all set to add (by pushing the volume buttons to make them light blue instead of purple)....after adding all of your channels (or just the one if you use dish) just power the tv off while on a channel and then power back on and you should have tv.
2answers
Is there a reset button on a onn tv model onc17tv001 because it is stuck on photo mode and I have lost the remote?
Just get a universal remote. Set it to your onn tv with onn codes or rca codes. Worked quick. Less than 5 minutes spent and it's fixed.
2answers
I can’t get my universal remote to take my on TV ONN off photo
Universal Remotes don't work with Photo Frames. Televisions, DVD and Cable Boxes only.
Or
Try this: with the TV OFF, hold down the MENU button on the side of the TV, and while holding it down, turn On the TV. That may get it out of photo display mode, if it is a typical ONN TV.Dec 26, 2018
It's on photo mode. Not old and it's a onn tv and 32 inch the ...
https://www.justanswer.com/tv-repair/bvozn-it-s-photo-mode-not-old-it-s-onn-tv-32-inch.html#:~:text=Try%20this%3A%20with%20the%20TV,is%20a%20typical%20ONN%20TV.
2answers
Got an ONN TV and an ONN soundbar. Hooked up via RCA cable. TV audio in PCM mode. Soundbar in AUX mode. Can't get any sound from soundbar. What have I missed?
PCM mode is a digital audio file that should be sent to the soundbar via an optical or coaxial digital audio cable. The coaxial digital audio cable uses an RCA plug but not the L/R stereo channels of analog audio. The aux input is usually the 3.5 MM cable from a computer, CD or MP3 player or a cell phone or tablet.
First, which type of RCA cable is connected between the sound bar and the TV? Second, are you sure that the TV connection is an audio out? (A number of recent TVs have only one audio output. This means there is only the optical audio out and not even a headphone jack.)
Once you double-check the input at the sound bar, choose the Line In input if you are using the stereo RCA cable. If you are using the Optical input, select that input. Use either the Mode button or the specific input button on the remote. Then double-check that the TV is set for the appropriate audio out.
I hope this helps. Please add a comment with the model of the TV and the sound bar for further information. I looked at the ONB18SB001 documentation for some of this. The manual for this Onn soundbar is available at Manuals Lib. See https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=12#manual for the list of input modes and the input to which they correspond. Here is the image of the inputs on the back of the ONB18SB001: https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=7#manual .
My onn new tv is stuck on some kind of usb camera mode and says no device how do i get that off so i can watch tv
Have you tried going into the menu and seeing if you are able to change the mode you are stuck in at present ?
Sanyo tv will not change channels
i have a sanyo tv dont have the remote i was getting all channels with cable its stuck on 1.1 cant get it back to channel 3 to watch cable
No remote tv stuck in cable mode no channel 3
See if you can get a manual for the set at web site or try a google search.
1helpful
4answers
Video mode
Hitachi F361 VCR Digital Auto Tracking (not 631!)
I had the same problem when I got the TV from someone and I didnt have a remote. I went out and got a ONE FOR ALL remote and once I got it set up I had it in VCR mode and hit the AV button and now I can get to the channels. Hope it works for you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
