SOURCE: Remote control codes
Juni,
You'll have to look it up by the remote you're using... Then by the brand of Tv you're trying to control.. try here..
http://www.remotecodelist.com/remotes/
Bill
SOURCE: Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
SOURCE: Remote Control Code for Element LCD TV -- & Direct TV
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
SOURCE: How I can program ViewSat remote to control JVC TV Volume
You need to hold down TV until all the lights on top cycle through. Then TV button should stay lit up. Press the channel up button do this with the TV on until the TV shuts off then press ok.And you should be good to go.
SOURCE: RCA L40FHD41 Remote key
The only way I could get it to work is use Philips Universal remote SRU4208WM/17. You must use the learning code.
