To flip the picture on your SEIKI SE32HY10 LED TV, you can follow these steps:
Press the "Menu" button on your TV remote.
Use the arrow buttons to navigate to the "Picture" or "Display" menu.
Scroll down to the "Picture Mode" option and press "Enter".
Select the "Flip" or "Invert" option from the list of available picture modes.
Press "Enter" to save your changes and exit the menu.
If your TV doesn't have a "Flip" or "Invert" option in the Picture Mode menu, you can try accessing the Service Menu to see if the feature is available there. However, accessing the Service Menu requires specific codes and steps, and any changes made in this menu can affect the TV's performance, so it's recommended to do so only if you're experienced in TV repair or have professional assistance.
Please disconnect all accessories. Then turn on your tv again. Please make sure that neither the power button on the tv or that on your remote is stuck because this could lead to the issues that you've mentioned. Otherwise, you'd need to factory reset your tv.
Press the Mute button ONCE. It is a toggle switch so if you press it twice for good luck, it goes back to mute.
Or try a Power Reset. Switch off and remove the wall plug. Wait 10 minutes. Hold down the power button as you plug it back in.
If the button is physically stuck, remove the batteries, put one drop of water on the button and leave if 5 minutes. With a damp cloth, work the button and it should release..
I never use such of TV but what I no your TV can be in stby mode plizbtry to use stby button on your handset remote controller, if you have no remote try to use buttons on your TV panal press v+ or v- buttons or try other buttons it can switch from stby .thanks
To get service menu mode on Seiki TV press on remote control - MENU - 0000
Do this at your own peril.
This is the true innards, and what you do there matters.
The Closed Caption function is set in the "text" mode. To remove it, access Closed Caption in the Main Menu and change the Mode setting from "text" to "off".
Hold down the physical power button the side of the television for 20 seconds. The television will automatically reboot into normal mode while you hold down the power button after that point.
