IF I SHOULD SEND A PHOTOCOPY WORK IT WILL ADJUST THE TOP OF THE WORK. EVEN IF I SHOULD SEND A PRINTING DOCUMENT IT ALWAYS ADJUST THE TOP. PLS WHAT DO I DO
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
SOURCE: MX2700N printer keeps giving A4 paper error.
Go to system setting, under printer setting there's a menu to forced output print or A4/Letter changing, if you can not find it try the key operator program/ admin mode ( default password for admin is admin )
SOURCE: I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
SOURCE: a new sharp ar 5316e photocopy machine photocopy blank
change the main charger because based on my experienced it has an arching problem
