If it gets stuck on the flywheel it may not be the right tooth count. or it may need a shim put between the starter and the engine block to separate the two
Http://manuals.deere.com/omview/OMUC11804_19/?tM=HO
If the starter engages and begins to turn the engine and then stops (starter stall), then likely overdue valve lash adjustment (200 Hrs by manual).
If bendix is getting stuck, see J Flowers answer.
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
SOURCE: my john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
