I want to make my answering machine works again normally.
SOURCE: BT Response 75 Answering Machine "memory full" problem
We have the same problem, but there are no apparent batteries in our unit. Is the 'Z1' component some funky battery and did you unsolder it? Thanks!
SOURCE: INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
SOURCE: GE Cordless answering system-27995
hi all i want to have inst. manual in english which isnt with me can anyone tell me how to download from net. thanks.Pls. also email to [email protected]
SOURCE: answering machine hangs up during greeting
this problem is cause by excessive loop current from telco. the answer to this is to put a 600 ohm resistor in series with either tip or ring to the cable which feeds the answering machine. excessive loop current related issues can be the toughest problems to troubleshoot
