SOURCE: line across top of screen
If the picture is ok otherwise then only thing that probably needs to be done is a vertical height adjustment. That is if the lines never changes position from cold to hot.
SOURCE: i have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
SOURCE: I have the kx-tg 4500
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
SOURCE: My Panasonic KX-TG2352PW 2.4GHz cordless phone has loud static.
I don't yet have a solution, but I do not want to be obligated to pay for your advice...so I will find another way to solve the problem. Thank you.
