SOURCE: Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
SOURCE: water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
SOURCE: water runs under the vegetable bins
There should be a collecting channel with a hole and a tube reaching down to somewhere above the cooling compressor (Back of unit) where it should evaporate with the heat.
Most people never clean that hole and tube simply because they do not know what is for or the manual is silent. Sometime can be jammed with little icecube. I us thick plastic line from toy to clean, electrical wire with copper core not naked is also oke. Do not put wild force. This is the cooler part. The deep freezer part needs defrosting on temporarily basis and for that you need some small low bin to start collecting or keep on mobbing the floor.
SOURCE: water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
SOURCE: Water in bottom of refrigerator under vegetable bins.
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
