C
Cynthia L Streepey Posted on Mar 21, 2019
How do I clear 2006h on display - Office Equipment & Supplies
We, 07 rendezvous park aid quit working. Needfixed
Rear Parking Assist Inoperative - Red Indicator Flashes
Does the red indicator flash ?
Diagnostic Aids
• The RPA system is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes from the RPA display. Before using this diagnostics, it is necessary to get familiar and understand how the on-board diagnostic feature operates. Refer to Diagnostic Trouble Code (DTC) Displaying and to Diagnostic Trouble Code (DTC) Clearing on how the diagnostic trouble codes are displayed and cleared from the RPA display system.
• Make sure the rear park assist (RPA) object sensors located on the vehicle rear bumper are clean and clear. Remove any objects that is blocking the sensors.
• Inspect for after market devices which could affect the operation of the RPA system.
This vehicle is equipped with an on-board diagnostic display feature capable of displaying diagnostic trouble codes using the 3 indicators on the rear parking assist display. After the bulb check has been completed, the red outside indicator flashes to indicate a malfunction with the system. The module disables operation of the URPA system under this condition.
In order to enter the diagnostic mode, complete the following actions:
With the ignition turned OFF, short the rear parking assist diagnostic connector to ground while the vehicle is in PARK. For the location of the rear parking assist (RPA) diagnostic connector, refer to Object Detection Component Views .
Turn ON the ignition.
Place foot on the brake.
Shift the vehicle into REVERSE within 5 seconds.
If the vehicle is not shifted into reverse within 5 seconds after turning the ignition ON, the diagnostic mode will still be initiated. However, a reverse input wiring fault will be registered as sequence #7 as shown in the Diagnostic Indicator table below. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes. After the reverse input wiring code is cleared, repeat the diagnostic trouble code displaying steps in order to enter the diagnostic mode.
When the diagnostic mode is first entered, the rear parking assist display displays the amber outside indicator and the red outside indicator. Then, the indicators on the rear parking assist display will display one or more of the sequences in the table below to indicate where the fault exists within the rear parking assist system. Refer to Diagnostic Trouble Code (DTC) Clearing for the specific steps on how to clear diagnostic trouble codes.
The Rear Parking Assist (RPA) Diagnostic Connector (UD7) is under the front of the center console behind the BCM - body control module.
How do i reset the sid display in 2008saab93turbo after replacing battery
pressing the CLEAR button for 8 seconds. on older 9-5 and 9-3 SID's, that you must press CLEAR once & release, then press CLEAR a second time, and hold for 8 seconds. While holding down CLEAR for this second time period, at the 4 second mark "CLEARED" will be displayed, and you will hear 1 beep. If you release the CLEAR button at this point, the DTE and MPG will be cleared out. If you continue holding the CLEAR button past the 4 and 8 second marks, you will hear a 2nd beep, and "SERVICE" will be displayed. This now means that you have cleared and reset the Time For Service message.
1helpful
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
I can't clear the Fax memory it say I have full memory. Tried * 3 & * 9 and nothing clears this message and I can't receive faxes
  1. Press the Setup button (c01361401.gif ).
  2. Press the Right arrow button (c01185072.jpg ) until Tools displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg ) until Fax Log displays on the control panel, and then press OK .
  4. Press the Right arrow button (c01185072.jpg ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  5. Press the Cancel button (c01235250.gif ) to exit.
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Maintenance display
Hello sir; You have to change drum & developer then go to simulation U109,110,111 & U130 after that you have go to simulation U250,251 & U345 then it will clear your display.
2helpful
T8008 printer with message says "replace fuser"
The 'Replace Fuser' message on the 8008 can be cleared in the following way;
• Power the printer Off
• Hold down FORM FEED and ENTER and power the printer on
Keep the FORM FEED and ENTER keys held down until the printer displays SERVICE MENU - INFORMATION
• Press the RIGHT ARROW to MAINTENANCE, and press ENTER
• The Display should read MAINTENANCE - CLEAR FUSER, if it does not press the right arrow until it does and then press MENU/ENTER
• The Display Should now Read CLEAR FUSER NOT EXECUTE, Press the right arrow until the display reads CLEAR FUSER EXECUTE
• Press ENTER, and after a pause the display should read COMPLETED CLEAR FUSER
• Power the printer off and after about 10-15 seconds power the printer back on again.
The message should now be cleared
After a power failure I am getting the code e1 f1 flashing on my display board and it will not go away.
q.gif Why is the display showing E"#"-F"#," for example, E1-F2?
Answer Is "PF" displayed on the control?
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
please do not forget to rate and comment about your experience today. Thank you
2answers
Kenmore 22082
OL on my washing machine
2helpful
2answers
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
k24674
