Hello Chiu, for what you describe, I think you have a problem in source, capacitors, that is why the clips are turned on, or you have problems in the power outputs, check the source capacitors, if they are not out of value and the transistors exit or attend a specialized technical service
Greetings Franco Dosil
Hola Chiu, por lo que describes, creo que tienes o un problema en fuente, capacitores , por eso se prenden los clips, o tienes problemas en las salidas de potencia, revisa los capacitores de fuente, si no est?n fuera de valor y los transistores de salida o concurre a un servicio t?cnico especializado
Saludos Franco Dosil
SOURCE: how do I set up and use the adanac 4000 stopwatch by marathon?
www.marathonwatch.com "Contact Us" They will email you the instructions.
