Question about Frigidaire Refrigerators
Frigidaire with on and off on control panel on front door,turn off for vacation now won't come back on
Model number ffhb2740peaa
SOURCE:
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
SOURCE: Frigidaire washing machine pump is making noise
Remove two screwn on bottem of front lower panel. Clamp hose clamp on large hose leading to front of pump assymbly, twist back and fourth the hose while pulling back to remove hose ( some water may flow if pump is not working right) Once the hose is removed you can see into the pump turbine and move it circular with a small screwdriver to see if it spins freely. I had this same problem and found a bobbie pin stuck partially into the pump. I removed the pin and everything works like new.
Posted on Mar 31, 2009
Todd_pdx
  • 22 Answers
SOURCE: Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
jumptrout51
  • 3361 Answers
SOURCE: Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Posted on Aug 18, 2009
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
Same thing happened - couldn't do anything - was completely "locked"...tried the breaker reset and it worked immediately. Thank you for sharing the answer!
Posted on Jan 10, 2010
Gallery. How can I remove the front panel?
Hey Mike, thank you for your post!
From the information you have provided you need assistance removing the front panel from your Frigidaire washer. In order to locate any additional information I would need to have your model number. You can locate the serial tag (which lists your model number) on the door frame of your washer. Once I have that information I would be happy to assist you further. -Matt
Feb 22, 2016 | Frigidaire Washing Machines
Frigidaire troubleshooting
Good morning friend, thank you for your post!
I understand that you are asking what the yellow light with a lock button on your Frigidaire washer means. Typically a lock symbol stands for control lock. I notice you did not provide your model number, if you comment back with your model number I would like to research to verify the information. Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. I look forward to your response.-Matt
Aug 17, 2014 | Washing Machines
Model number FGEF3032KWB frigidaire oven door won't unlock
Unplug, or turn the household circuit breaker off to the unit for about 15 minutes. If the door does not unlock itself then, contact Frigidaire for a service call. The door latch and/or control board will need to be replaced.
Aug 02, 2012 | Frigidaire FEF336BC Electric Kitchen Range
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
I don't know how to turn on the door panel
I had same issue. The control panel had been set to Sabbath mode. Hold down the "DOOR ALARM" button for 3 seconds. Then lights will turn on on both display windows. Scroll using the + and/or - sign on the left side display until "SAB" is shown. Then scroll using the + or - sign on the right side display until OFF is shown. Finally, hold the "DOOR ALARM" button down again for 3 seconds. All should be good to go!
Aug 29, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Water drips from under door. the water is
There is a ventilator mechanism on the top right corner, behind the control panel / front cover.
******TURN THE POWER OFF AT THE BREAKER BEFORE STARTING, BE SURE POWER IS OFF ******
Open the door; remove all of the screws that hold just the front panel (not the controls panel). These screws are located on the inside of the door, around the outer edges. The front door panel will be able to be removed. Close the door with the front panel removed.
***IMPORTANT be sure nobody will come in contact with the exposed wiring (especially little kids) *********
Turn back on the breaker, turn on the washer, and run a quick rinse cycle. See where the water is coming from.
On my washer (same model) i had to replace the entire vent kit (sears parts ~$40.00) Call them with your model and serial number, or search online. Removal and replacement was very easy, and it did fix my leaking problem. Checked with the front door panel off and a quick rinse before I TURNED POWER BACK OFF and put the front cover back on.
Root cause?? From what I can tell, the solenoid stopper hardens over time, which allows for water from the spray arms to leak past.
Get it fixed now before you smoke the motor or control card. My part number was ABT35083501 be sure to double check model before purchasing.
Jul 17, 2009 | LG LDS4821WW 24 in. Built-in Dishwasher
Panel resets
Hi Tim, there was a service flash out on this model which has to do with the circuit board in the dispensor. Frigidaire has redesigned this board causing your problems. This should be covered under this service flash. The number of the service flash is 46-470. The solution is to replace the water filter and dispenser board. Contact Frigidaire and inquire about the service flash. Refers that were included in this flash have the serial numbers between LA113---- to LA146----. If yours fall into this range you should be covered. Circuit board kit number is 240533603. Your model is included in this flash...Catriver..post back.
Aug 21, 2006 | Frigidaire PLRS267ZAB Side by Side...
Refrigerators Logo
49 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
