Dual Electronics CECT P168 Cellular Phone Logo
Posted on Aug 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone cuts out
I'v had my i9 p168 for about 8months and last night the screen went blank but the buttons stayed lit, i couldn't turn the phone on and have 2 remove the battery and pop it back in in order to get it to work. even then it doesn't last long before it goes back to blank screen with lit buttons and freezes in this state. earlier the phone switched itself back on from this state and worked for about an hour allowing me to text but cut out agen when i made a phone call. the charger charges the batteries normally and says they are fully charged. i don't understand why or what i can do to make it work again
  • SALMAN NASEER May 11, 2010
    dear, you have to check it by removing battery.. if doesnt work then surely its strip problem... the flip and slide phone have this kind of issue...you have to check it by an expert tech.. goodluck.....
SALMAN NASEER
Level 3:
Genius:
  • Master 1,011 Answers
  • Posted on Aug 06, 2009
SALMAN NASEER
Master
Level 3:
Genius:
Answers
1011
Questions
Helped
309404
Points
3022
Dear, you have to check it by removing battery.. if doesnt work then surely its strip problem... the flip and slide phone have this kind of issue...you have to check it by an expert tech.
. goodluck.....
5helpful
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Blank screen on Sciphone I9 ++++
Go to some mobile repair shop and ask him to flash it completelt ,
If not then change the screen
My screen went black. Worked the night before.
hi..
when the unit is on try to press and hold the reset button for 10 seconds and then release if this will not work charge the unit for 3 to 4 hours using a wall adapter and if still not work try to check if there is a latest firmware update for the gps then download it.
thank u
rate me!!
Jul 15, 2009 • Garmin GPS
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Blank blue screen
Comment by suekanos, posted on Jun 03, 2008 this phone was just switched off in the night.the following day when i tried to switch
2answers
2answers
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
1helpful
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Won't turn off unless unplugged
Ther eis a stand by function on the Television. If you have the owners manual read about that function. Th ered light stays on because it is programed to come on a t a certain time. Go to menu and find the stand by function.
Top Dual Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
john h
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
