After removing all of the obvious screws, It seems as though the front fascia need to be removed in order to access a couple of retaining screws.
SOURCE: Remove hard drive
the hard drive has screws on both sides so you may have to remove the oder side of your case in order to remove the hard drive
SOURCE: Removing Old Built-In Microwave
You did not note your Make and Model. As there are many different types, all I can give you are basic directions.
First make sure the Power Cord is UN-PLUGGED from the wall.
1. Remove the Top Vent Grille Cover. There are screws holding this on, either Three you can see (one on each side and one in the center), or Open the Door and look for screws at the top of the Frame that go Up Into the grille.
2. Look in cabinet above unit for screws that hold unit up. Usually two (one on each side, front), can be more. Remove.
3. Look where Top Vent Grille Cover was removed. There should be a Long Screw or Screw-Type Lock at each( top) corner. These hold the unit tight on the Wall-Mount Plate. Remove. You should have HELP at this point as you will slide the unit forward until it comes clear of the Support Arms.
GOOD LUCK!!
SOURCE: Removal of outer door
Not sure if this has been covered - how to remove the door from the oven.
If you look at the hinges theres a pivoting piece (under all that grease) like a zippo lighter lid. Flid that open towards you and the oven door will pop out when pivoted closed - hinges and all. It should be fairly easy to put back too. Then follow the other instructions - screws on door base.
SOURCE: Roper Washing Machine Repair
I believe Roper washers are manufactured by Whirlpool. The following link should provide you with the necessary steps in removing the washer casing, so you can access the pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this information is not correct, or if you require additional assistance, please let me know. I hope this helps you.
SOURCE: how do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
