Sharp model: LC-50LE440U if power settings ok possible bad transformer
SOURCE: OWNER'S MANUAL AND A REMOTE FOR A SHARP SHARP 46'' TV MODEL lc-46s
The mauual you can get from the internet by Googling it will be in PDF format that you can print. The remote use a Universal cheap GE is good and program with one of these codes....
0079, 0123, 0063, 0020, 0004, 0009, 0226,
0266, 0006, 0095, 0122, Low cost approach.
SOURCE: What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
SOURCE: is a flashing power light on a sharp model # LC-19SB24U tv
push vol-, input, and power, at same time. keep push until tv start. Then you will see k123 at your screen. Now push vol-, and chan- at same time. You will enter service mode. Look for "error no reset" change the value to 0.
SOURCE: Sharp lc 32sh20u when power
WELL FOLKS I just FINALLY found what I have been searching for, I own a Sharp LC 32SH12U LCD TV that has begun to show problems with it's picture, Now it's sound is great no change..But it has gotten to the point that when i first turn it on all I get are three or four bright WHITE lines on the right side of the screen. They are a bout one third from the very corner of the screen.After it warms up for a while, MOST of the time it will just pop up and go to working just fine, that is what was giving it away to me that it HAD to be a something generally easy to fix, And in all of my searching I FINALLY found what I was looking for..Rite here on FixYA.com...There it was right thre in PLAIN ENGLISH..(( The T-CON BOARD )) Timing Control or LCD Controller..Board. on teh LCD panel Assembly, It transfers the image signal of the TTL and LVDS signal to specific TFT but What you all really NEED TO KNOW is JUST what is going on with your TV set when the T-CON Board is going bad, And I am about to tell you....So her ya go.. If you TV has any of these symptoms Well then I can pretty much say that your T-CON Board is bad or going bad...OK..If you have A Scrambled Picture,LINES,multiple Pictures Color smears, blotches, Rolling Pictures after warm up, Blown Surface mounted Fuse No Picture, Very Dark Screen almost like there is no backlight....Folks if your SHARP LCD TV is doing ANY of thsi then you just may need to replace your T-CON BOARD!!!! Hey it beats buying a new TV RIGHT!!!! GOOD LUCK FOLKS!!!!! I have already bought my replacement T-CON Board, as soon as I get it and install it I will let everyone know how it went!! PLEASE CROSS YOUR FINGER"S AND PRAY THAT THIS WORKS FOR US!!!! Thanks Wade in Eastman Georgia...
