SOURCE: Lexmark X4850 Wireless wont connect
Had a similar problem with my router, which was a 2WIRE router (furnished by AT&T - I have Uverse). Fixed it by going to the router's GUI (mine is 192.168.1.254), click on "View the home network". On the right side of the resulting screen, there is a section titled "wireless settings". Under that, click on "edit settings". Enter the login information (the default password is on a tag on the router). The next screen is "Configure the Wireless Network". Scroll down to the bottom and click on "Rescan". When I did this, my X4850 miraculously connected and started working.
Rick from Austin
SOURCE: enable wireless card and key number pad
To turn wireless on (or off) press the Fn and F2 keys together.
To enable (or disable) the number keypad, press the Fn and "scroll" keys together.
Here is the online manual for your laptop:
http://support.gateway.com/s/Manuals/Mobile/8511184.pdf
If this solution worked for you, please don't forget to rate me! :) Best of luck.
SOURCE: it wont connet to my belkin wireless router
Hi...to find the password, or network key:
1) Login to your router.
To do this, open a web browser on a computer, as if about to view a web page: then type the router address, http://192.168.2.1 in the address bar.
2) You should see a prompt asking for a password. Just click 'submit' button if none has been set: otherwise, enter the correct router login password.
3) You should see the router user interface. In the left hand menu, under Wireless, click Security.
The 'Pre-Shared Key' or PSK you see there is the network key (password) you need.
Please come back to Fixya if this doesn't work or if you need help with any of it. Good luck
SOURCE: where is the wifi password for my 2wire wireless
the default wireless passowrd or network key is located at the bottom left of the 2wire router. You will find a sticker that indicates the Serial Number, System Password and Wireless Network Key. The Wireless Network Password is is the 10 Digit Code located under the S/N.
If in any case you want to personalize the Wireless Network Key. You can access the gateway by opening a browser the type 192.168.1.254 it will ask you for a password use the System Password on the sticker. Click on Home Network then Click on Wireless Settings. You can also change the Network Name or SSID, The Authentication and the Wireless Network Key
Thanks for using Fixya
SOURCE: The exclamation point light on
you have to check paper settings (letter, A4..etc)
For examle - > if you trying to print A4 but printer expecting Letter this error will occur...
If you using Windows XP - .> click start button, then click on Printer and Faxes, select your printer and then click right mouse button on him, select Properties, then click Printing Preferences, now click on tab Paper/Quality and select right paper format...
Rate me if i'm usefull :)
