SOURCE: Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
SOURCE: DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
SOURCE: Capstan motors of Teac X7 rotate only manually (very stiff)
Allied electronics still has these small motors. They probably won't have the same part numbers though. You will need the printed information from the motor as well as accurate dimensions for an accurate comparison.
Good Luck.
SOURCE: Some bands OK some not. No transmit, no readout on some.
its the problem of the frequency range its getting blocked at particular location.these can be solved by two options
1)first try changing the location of the unit from one corner to another corner.that should help to catch the frequency again if its getting blocked at particular location.this happens many times.but if changing the locan does not make any difference.then
2) get checked that the antenna of the unit is not catching the required frequency for the unit.so change the antenna also connect this external antenna as mentioned 50 ω (it comes wioth SMA Connector) that helps in catchinf the frequency.
you will get this at radio shack website. this will help.
also in the unit there is a component which controls the frequency called microprocessor if that goes weak the unit slowly slowly stops receving the accurate signals and only the noise comes.so the micro processor in located internally in the left side.its a green and black colour mini chip circuit board.many times opening the unit and removing and cleaning the microprocessor and refitting it solves the problem but this is 50 --- 50 chance.
this all has to be checked what mentioned.
thank you for using fixya.
SOURCE: Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
