Televison & Video Logo
a
azhar ali Posted on Mar 21, 2019
I have sony Bravo TV but cannot change channel to 2 Digit
sandeep star
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Mar 21, 2019
sandeep star
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
323
Points
13
First of all you go the dish connecter shop
4 Related Answers
Michael Borelli
  • 979 Answers
  • Posted on Oct 20, 2007
SOURCE: 3 Digit Channels
Make sure the tuner is set for Cable and not broadcast...accordianman
Anonymous
  • Posted on Mar 30, 2009
SOURCE: Akai LCT2662N Channel Changing Problem
there is a button that controls how many digits you can enter. it is located betwwn the 0 and source or below the 8 buttons
Anonymous
  • 374 Answers
  • Posted on Jan 11, 2010
SOURCE: Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Anonymous
  • Posted on Oct 05, 2011
SOURCE: Sony Bravia Digital TV won't
These numbers are the LCN (Logical Channel Number) assigned by the broadcasters. It will only be at 350 if it is the same channel from a different transmitter. You need to know the 'channel' of the frequency to manually tune it in. You are talking about the program number not the channel (frequency), a common mistake. i.e ABC in Sydney is transmitted on CH12 (226.5Mhz) and the LCN's for each program are 2,21,22,23,24,201 & 201. If your antenna also picks up the signals from the Kings Cross transmitter ABC is CH30 (543.5Mhz), as these are later in the spectrum they are put in the LCN list starting at 350.
How do i find my TV's pairing code?
It's either in your TV settings or you could try some of the generic codes such as 0000 1234 9999
1helpful
Code for sony tv
Hello
Three digit universal remote codes for Sony are:
002/ 006/ 071/ 128
For GE TV are
000/ 003/ 004/ 009/ 022/ 031/ 044/ 052/ 054/ 055/ 087/ 092/ 103/ 107/ 125/ 164/ 181
Four digit universal remote codes for Sony TV are:
0128 0013 0002 0071 0380
For GE TV are
0031 0107 0164 0004 0009 0044 0054 0000 0342 0003 0125 0015 0022 0052 0087
Your post contains both Sony and GE; and so I gives here codes for both brands.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Remote control codes of sony
Hello
Three digit universal remote control codes for Sony are:-
002/ 006/ 071/ 128
Four digit universal remote control codes for Sony are:-
Direct Code Entry
OK.
Cannot change channel to a 2 digit channel eg.
some remotes used to have a key to switch between single or double digits marked ( -/--)
Tv programming
This TV doesn't have channel labeling. You'll need to keep your cable channel card handy, sorry to say.
1helpful
Insignia IS-LCDTV32 32" Wont let me change channels or go to menu
there is a problwm wit hyour mainboard you can buy one on ebay for about $80 and to remove just take off back panel and unplug about 5 wires and remove 2-3 screws on the left side / the same side that your power ch+/- ect is on. and swap out.
please rate my answer it is much apreceated
Remote only advances by one channel.
The button on the remote next to 0 and below 9 has to be depressed to _ _ before you select any 2 digit channels. I had the same problem and accidently figured it out. Hope it helps. TC
2answers
How do you change the channel =S
usually you have a channel up and down
it looks like an awwow nowadays and is somtimes abbreviated like chn up of chn down
3 Digit Channels
2answers
My SONY TV remote control doesn't do what it should
problem due to dry soldering remote microprocecer
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
