SOURCE: personal password
From knowyourmobile.com:
Forgotten your iPhone Passcode?
If you have forgotten your iPhone's Passcode you will need to restore your phone via iTunes.
But first you have to put your phone into the restore mode which is a slightly fiddly process.
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode. You should then follow the steps above to activate the Passcode with a memorable number
SOURCE: i cant remember the code to unlock my glyde, the
The code that your looking for would be the factory reset code.
that is the only code to reset a Samsung Glyde mobile phone
{Note a factory reset will reset all data and erase personal info.
if your able you should save all personal files and numbers.
The code is. Press
*2767*3855# followed by #*7337#
Reboot phone and password will be reset.
This was recently posted on fixya by rain_catcher
SOURCE: how to unlock phone when
Attempt the pattern Five times then press Forgot pattern? and sign in with your Google acount.
From Lewis
P.S. Would you like a video explaining how to do it?
SOURCE: I've forgotten my security pattern for unlocking
You can perform a factory reset of the phone by:
-Turn the power off.
-Hold the Volume Down button
-Press and release the Power button
You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
-Select Clear Storage by pressing the Volume Down button
-Confirm your decision: Volume Up for YES and Volume Down for NO
-If you selected YES, all data will be deleted from the Samsung Galaxy S.
