I can't put it in the release position to cast.
SOURCE: automatic gearshift stuck in park
The release for the shifter is tied to the brake lites, check to see if the brake lights work, if they don't then test the brake light switch at the top of the brake pedal, if it lights a test lite when you press the brake it is ok, in that case you need to check the little solenoid that pulls the cable to unlock the shifter, it is bolted to the top of the steering column, in order to get at it you will have to unbolt the column and drop it dow.
SOURCE: Auto gear lever gets stuck in Park
Brian... i would respectfully advise you that the other site that bocon has given you is a scam.
I'm not sure if you are driving in winter conditons.... but first replace the interlock relay and see if that corrects the problem... and it should. it is indeed the interlock solenoid that will need to be replaced.
Robert
Please rate this solution
SOURCE: 2002 Ford Escort: Shift lever stuck in Park position.
we do not have an escort but we are having the same prblem with our expedition...it is the break sensor switch near the petal and only about $13 dollars to repace. Easy plug,unplug instal
SOURCE: Seat adjustment forward and back stuck
I had this problem not to long ago, it's a very easy fix! I agree with that garr651!
There is a a thin metal wire that runs from the left & right side under the seat. Each end of the wire loops around a small hole on each track bracket and is held in place by two small washers that fit inside a grove.
Check to see if the washers are in the groves and holing each end of the wire tightly. If they're not simply slide them back into place and make sure the wire tight.
The easiest way to do this is to look under the driver seat from the back seat. Also a pair of needle nose pliers may become handy (although not necessary).
