F1 error (On a Fisher Paykel dishdrawer means there has been a water leak and its triggered the flood device. The machine wont let you use it as a safety precaution. You need to get an F&P Tech to look at it before it causes more damage. Often the drawer seals fail or the heater plate springs a leak.
SOURCE: fisher & paykel top drawer stuck again
Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
SOURCE: bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
SOURCE: top drawer sticks
Hi and welcome. I think I can help here.
Read over my instructions first before pressing any buttons- Set the machine in diagnostics mode by first pressing the small lock button and holding it down, followed by the center button. (hold them both together, but start by pressing the lock button FIRST) for about 6 seconds. (you have to press the center button down right after you depress the lock button or else you will just set the machine in LOCK mode) You will hear a BEEP. Now push the far left button once. Now look at the display and press the center button to scroll thru the codes. You want to find "LD", I believe you will see it after three sucessive codes from the begining, but either way, scroll thru until you see LD, and then press the small lock button once. You should hear the lid motors retract now, and you will feel the drawer "come loose" again once the lid motors are back in the retracted position. Then simply turn the machine off. This clears the diagnostic mode. That should free the drawer up. Try this first and if you still have problems, let us know.
Happy New Year from the FixYa crew!
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
SOURCE: Fisher Paykel Dishwasher drawer not draining
F1 means that your machine has activated the flood switch. check the drain hose that is connected to the sink pipe is not blocked. remove clip holding hose to pipe, put end of hose into a bucket and turn on cycle. it should start draining straight away. if it does drain into bucket stop cycle and clean nossel of sink pipe with a small screwdriver. then refit hose and turn on cycle. if it doesnt drain into bucket please reply and i will guide you thru how to check to see if you roto motor is jammed or faulty.good luck
Testimonial: "I have not tried your suggestion,but will tonight...Thanks for the fast reply....let you know how it goes...Thanks "
