SOURCE: peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
SOURCE: why my 28v doesn't fully charge
One or more cells of the battery have gone bad. The technique of measuring the state of charge of the battery is VERY limited.
I would recommend letting the battery cool after charging... THEN in a day, charge it again without using it. Do this for several days and see if the battery improves. If not, time for new battery.
DO NOT discharge these batteries beyond the point where the tool starts to slow down. You will reverse charge the weakest cell from the ones still deliveing power and the reverse charge will permanently damage the weakest cell.
SOURCE: New Hitachi 3.6v HXP EBM315 Li-ion battery won't take a charge
when i turn on my drill amoked comes out hohw can i fixed it????
SOURCE: Ryobi Model 1412001, 16vdc, 2A
I had the same problem. No need to repeat it here, but I found this solution worked for me. In case I didn't embed / post it right, copy / paste this into your browser: http://youtu.be/GhRQZEeQzP0 Hope that helps
SOURCE: Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
