oscar sevilla Posted on Mar 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how can I check the ink level. I press the scan copy, or fax buttons and appears a narrow line in black. How can I know if I still have enough ink for some impressions..
Jim Hicks
Level 3:
Master:
  • Master 661 Answers
  • Posted on Mar 21, 2019
Jim Hicks
Master
Level 3:
Master:
Answers
661
Questions
0
Helped
205777
Points
1952
I DON'T KNOW. FOR SMALL LIQUID INK CARTRIDGES
USED IN SMALL HOME PRINTERS, YOU CAN JUST HAVE THEM REFILLED. MOST PRINTERS ONLY SHOW A
PRETEND INK LEVEL. AT THE FIRST SIGN OF FADING, STOP AND REFILL OR REPLACE. ON MY CANON INK JET PIXMA PRINTER, I CAN BY PASS THE MAKE BELIEVE 'OUT OF INK' NOTICE BY HOLDING DOWN START BUTTON FOR 20 SECONDS.
5 Related Answers
Anonymous
  • 247 Answers
  • Posted on Apr 04, 2007
SOURCE: Black lines on scanned copies
Try this. Lift the lid to expose the top glass. To the left of the main glass panel, you will see a narrow glass strip. Clean this strip using a soft cloth or sponge moistened with a nonabrasive glass cleaner, then dry it off with a dry chaois cloth or cellulose sponge. A.
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Oct 27, 2007
SOURCE: Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
  • Posted on Nov 30, 2007
SOURCE: black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Dec 03, 2007
SOURCE: black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Ajkill
Anand Kumar
  • 2035 Answers
  • Posted on Nov 11, 2008
SOURCE: two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
3answers
Getting lines on copys and scans
While on remove power cable from printer wait 2 min, attach power cable again, , or scan glass is dirty
Black line scan
Open the scanner lid and clean the narrow glass in the left-hand part of the scanning area. Look for remains from ink or corrector at the far end and wipe them out. The narrow glass should be entirely clear to make good copies from the feeder.
Black ink not working lexmark pro915
Check ink level, clean contacts on cartridge and machine.
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
1helpful
How to fax?
This section describes dialing and sending faxes directly using the Numeric buttons.
note:
  • A PBX (Private Branch Exchange) is an on-site telephone switchboard. If your machine is connected through a PBX or other telephone switching systems, you have to dial the outside line access number first, and then the number of the party you are calling.
Sending a Fax with the Numeric Buttons .
Click here for other useful sending methods.
1. Preparing for sending a fax.(1) Make sure that the power is turned on.
(2) Load a document on the Platen Glass or in the ADF.
important:
  • When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
(3) Press the FAX button.
The fax standby screen will appear.
(4) Adjust the density (scan contrast) or image quality (fax resolution) as necessary.
See "Adjusting the Sending Quality"
2. Sending the fax.
  • When the document was loaded on the Platen Glass:
(1) Use the Numeric buttons to dial the recipient's number.
(2) Press the Color button for color sending, or the Black button for black & white sending.
important:
  • Color sending requires that the recipient's fax machine supports color faxing.
(3) Press the OK button.
The machine starts sending the fax.
note: When loading two or more documents
  • Load the next page, and press the same button as you pressed in (2) of step 2. Repeat the same procedure to scan all pages of the document, and press the OK button.
  • When you have sent the first page with the Black button, the following pages will be sent in black and white.
When the document was loaded in the ADF:
The machine scans the document automatically and starts sending the fax.
important:
note:
  • To cancel sending a fax, press the Stop button, and follow the instructions on the LCD.
  • If documents remain in the ADF after pressing the Stop button during scanning, "Close the feeder cover [OK]Eject the document" will appear on the LCD. Press the OK button so that the remaining document is automatically fed out.
Automatic redialing
  • When sending a fax and the recipient's line is busy, the machine will redial the number after a specified interval. Auto redial is enabled by default. Auto redial can be enabled or disabled by selecting ON or OFF. Select ON to specify the number of redialing in Redial times and redialing interval in Redial interval.
Redialing the Number Dialed with the Numeric Buttons
1.Prepare for sending a fax.
(4) Adjust the image density (scan contrast) or quality (fax resolution) as necessary.
2. Select the telephone number recently dialed.
(1) Press the Redial/Pause button.
Most recently dialed fax number using the Numeric buttons will appear.
(2) Use the g0016984.png (-) or g0008875.png (+) button to select the number to redial.
The selected number will appear in the fax standby screen.
3. Send the fax.
important:
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
How do you remove black lines from fax copies?
the glass need to be clean. Even though the glass look clean lines in the copies or faxes can appear. And its normally when using the document feeder. Lift the lit and clean both glasses. The big one and the narrow one at the very left. Use windex or something like that to clean it and try again. If the lines also appear when printing from the pc the issue can be other (fuser, toner, or rollers) try running a couple of cleaning pages from the service menu: press the wrench and with the arrows look for service, press ok and look for cleaning page and press ok again. Good luck
1helpful
When I fax the recieptent is getting 2 big black lines..........ive tried cleaniung it but not sure if im cleaning the corredt parts..........there a little glass part that looks like there may be ink
Open the auto sheet feeder (where you place your originals), look underneath and you will see a narrow "scanner" glass that the originals are scanned across. Clean this thoroughly with glass cleaner (or water) - there is probably correction fluid or some other foreign dirt on it. If you make a copy for yourself (before and after) it gives a good indication of the quality you are sending to fax recipients.
good luck, and please rate solution
Copier feature (Black or Color) only produces a Black page
I beleive you are not able to make a color copy, once try to scan from the computer or all-in-one to check whether the scanner mechanism is working properly or not, if the scan comes out fine then remove the color cartridge and clean the copper contacts of the cartridge with soft cotton cloth and also check the ink level of the cartridge, if the issue persists replace the color cartridge and if even the scan does not comes out good then there is an issue with the scanner mechanism.
8helpful
6answers
Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Top The Office Equipment & Supplies Experts
vince
littlewheel
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
