SOURCE: Recorder says "PLEASE DOWNLOAD FILES," but there are no files to download
The DS-2 has a format option in the menu under submenu. After you choose start you will see a progress bar and it should return to full record time. Use on a MAC seems to cause the reduced record time more often than on a PC.
SOURCE: Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
SOURCE: static when trying to record or play back audio
This cannot be windows, this has to be a lead problem to your speakers or the speakers are damaged.
SOURCE: RCA Digital Voice Manager software for RP5120 "warning decoding"
Bad News... I spoke to AudioVox/RCA (800-894-0956 < Direct DVR Number) and they told me that once you get this notification of a bad file format, there is NOTHING that can be done.
I tried DOS, too. Nothing worked.
The only thing left to try is connecting the recorder to the computer via a cable from the line out of the DVR to the line in of the audio card, and record from there. I'm going to try this, then return the recorder, if possible. Mind you, I've gone through several of these recorders and all of them have had this problem... eventually.
The customer service person there at AudioVox/RCA was direct, helpful, but clear that I couldn't do anything but reformat the recorder. Though she didn't really seem to care, by her tone, one way or another. They were still reproducing this product even with the flaws that exist (they certainly did not take ownership of the problem... they said it was out of their control and the problem was just like a virus).
SOURCE: SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
