Question about Kipor Electrical Supplies
I have an early model Kipor KDE 6700TA generator which starts and the shuts down after 30 secs with the LH Propect light on, I have checked the oil and changed the oil pressure sensor
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
I would try disconnecting the oil pressure sensor temporarily to isolate that circuit as the possible cause of it shutting down.
Posted on Apr 15, 2019
3 Suggested Answers
SOURCE:
CarlGehrke
  • 169 Answers
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Posted on Feb 23, 2009
sal_kh_sab
  • 98 Answers
SOURCE: KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Posted on Oct 25, 2009
Testimonial: "Khan sb. truly is a professional. "
Generator kipor 6700ta, run for a few second and stop, any solution?
hi
you may want to check the filter in the tank if one is fitted check damage fuel line , insure that fuel tank cap breather hole not blocked and injection system
Dec 09, 2017 | Electrical Supplies
I have diesel generator Kipor kde 19 STA3 . It keeps shoutinng dowen after it starts
First check the oil, A low oil sensor will shut it down if more than a quart low. Then drain your water separator and change fuel and air filters. Anything outside of that is going to be mechanical (lift pump, injection pump)
Jul 17, 2017 | Cars & Trucks
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Kipor kde 6700ta GENERATOR
There is, on most generators, a fuse of approximately 8Amps in series with the charge system for the battery.
If the generator produces AC and there is no charge to the internal battery, I would suspect the altenator winding, diode pack or regulator.
Nov 14, 2013 | Computers & Internet
I start de generator ahd the light of L.H.propect is on and emergenci stop and off de generator.
check your oil level. many generators have a low oil level light and will shut off to protect the engine
May 30, 2010 | Electrical Supplies
Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Aug 18, 2009 | Electrical Supplies
Aug 04, 2009 | Kitchen Appliances - Others
Regards,
Carl
Feb 19, 2009 | Kipor Electrical Supplies
Electrical Supplies Logo
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
