Question about Janome Sewing Machines
I have a Janome 6019 and wart to know where is the reverse switch
  • Janome Master
  • 5,833 Answers
The Janome 6019QC has the reverse stitch button to the right of the threading path below the thread tension dial. The thread tension dial is under the top cover but the two points help triangulate the button. The reverse stitch button is shown as item 27 on the first illustration of the parts of the sewing machine in the manual (page 2 of the manual, page 4 of the PDF). Janome has the manual on the retired machine page: https://www.janome.com/support/retired-machine-manuals/ . The manual is in the right-hand column under the Other Machines heading. The current link to the manual is https://www.janome.com/siteassets/support/manuals/retired/other-models/inst-book-6019qc.pdf .
I hope this helps.
Posted on Mar 21, 2019
4 Suggested Answers
SOURCE:
SOURCE: need help with automatic buttonhole for my Janome
Right, now I've figured this out :)
Put your button in the holder on the foot - fiddle about with it enough and I'm sure you'll work out how, one bit slides open and then you can close it again to hold the button.
Then fit the foot to the machine - the piece with the button in goes at the back.
Select 2 on the stitch selector, 4.5 on the stitch width and buttonhole on the stitch length.
Using scraps make up a piece of fabric with the same number and construction of layers as your finished garment and do a practice run or three.
You can set the actual feed length using the -.+ control (beside the feed release switch at the front, below the sewing table).
Between button holes you need to reset by turning the stitch selector wheel slightly until you hear a click.
Once you're happy with the method, think you have the settings as you want them and feel you have done enough practice try it for real on the garment.
Note: the button holes come out a bit long - just don't cut down the whole length or you may need to hand sew them tighter.
Posted on May 01, 2009
hazelgrace
  • 340 Answers
SOURCE: how do i change the
On most sewing machines the light bulb is located inside the faceplate on the left hand side of your machine.
http://www.janome.com/documents/File/ManualFile/6019QC.pdf
The faceplate is part number 17 in this manual.
One that has been removed, the bulb should be visible. You will need to look at the old bulb to see if it a screw type or a bayonet type, in order to replace it with a new one.
If this is not correct try the Janome website for advice, they have a forum and an ask Jan section for problems etc.
http://www.janome.com/index.cfm/LearningCenter/AskJan
http://www.janome.com/fusetalk/forum/
I hope this is helpful to you!
Posted on Sep 17, 2010
mitologia90
  • 42 Answers
SOURCE: need a service manual for a janome 6019
take a look here
Posted on Apr 10, 2013
I can't remember how to go reverse on my Janome JD1822
The Janome JD1822 has a reverse button on the right side (motor section) of the sewing machine. It's roughly on the same level as the sewing bed below the stitch width indicator window. Press and hold the button for the entire period that you wish to sew backwards.
The manual for the Janome JD1822 is available from Janome on their retired machine support page: https://www.janome.com/support/retired-machine-manuals/ . The link for the JD1822 is near the bottom of the list of Other Models in the right hand column. The direct link to the manual is https://www.janome.com/siteassets/support/manuals/retired/other-models/inst-book-jd1822-enfr.pdf . The position of the reverse button is shown on page 4 (page 6 of the PDF). The use of the reverse button is on page 20 (page 22 of the PDF).
I hope this helps.
Oct 20, 2018 | Janome Sewing Machines
How do I sew a buttonhole on Janome 6019
most likely by setting the machine to that function ..rereading the instruction manual would be my first option .
Jul 31, 2015 | Janome 6019QC Mechanical Sewing Machine
The reverse button does not work
The button is a relay switch and is an electronic component
Quite easy to replace, but you need to get parts from Janome Authorised Dealer
Feb 28, 2015 | Janome D'cor Excel Pro 5124 Mechanical...
Why is my Janome Mystyle 20 stuck on reverse?
It may be in the buttonhole mode, change the stitch selector to straight stitch.
Jul 16, 2014 | Janome Sewing Machines
How do I change the position of the needle (right/left) on my Janie 6019 QC sewing machine?
You may only be able to adjust this one or two spaces. When you have the straight stitch selected, try moving you stitch width slide wider. If you needle is in the correct position, you should see it move as you slide the lever.
Sewing Machine Tech
Oct 24, 2013 | Janome 6019QC Mechanical Sewing Machine
My sewing machine Janome Model 2139N only sews in reverse. I have pushed the reverse button many time to avail. Help--Donna
I think that the spring either unhooked or broke. Take off the case an see if you can spot it. There are videos on youtube.com for removing cases and sometimes even have free videos for repairing machines. Good luck
Dec 10, 2017 | Janome Sewing Machines
How do i change the lightbulb on my Janome 6019 sewing machine?
Sep 17, 2010 | Janome 6019QC Mechanical Sewing Machine
Howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Apr 02, 2009 | Janome 6019QC Mechanical Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
