SOURCE: My car alarm is blinking
you can try switching the key to the "on" position then open the hood and disconnect the negative terminal of the battery and reconnect after 2minutes. this will allow the alarm to be '"reset" and will recognize that you have the key for the vehicle.
Your Central locking wire is short from any one door side. Please check it properly.
You need to first look under the drivers side dash area near the hood release/fuse panel area and see if there is a valet switch. The switch will look like a little toggle or a push switch. After you locate it, turn the ignition switch to the on position(dont start it) and flick the valet to the opposite position it is in now. If done correctly in most cases the red system light will stay a constant instead of off or blinking indicating you are in valet mode. Next try to start the engine. If this doesnt work you need to remove the alarm system and repair the ignition switch wiring or replace the electrical portion of the ignition switch. The aftermarket alarm cuts into the ignition switch wires and bypasses the start circuit through the alarm module. When disarmed the alarm completes the circuit and allows the car to start. Good luck hope this helps and please rate this.
SOURCE: Sliding door alarm sounds constantly
there must be a switch some where , around the door to shut it off when door shut
SOURCE: door ajar light will not go off and all doors are closed
I had this problem. I had to have a sensor in the door replaced.
