SOURCE: Insignia Flat Screen TV - no cable signal
Hi, need some help here. I have a flat screen tv that will not go on. Its not even 2 years old. Yet I had to keep trying the wall outlet to get it to turn on. Now it won't go on at all. The tv light use to be blue when it was on. Now its pink? Should I ask santa for another, or can this be repaired without too much fuss/cost? Thanks!!!!
SOURCE: Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
SOURCE: Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
SOURCE: Verizon fios remote cant be programmed to control insignia tv
Orion code 0490 solved it for me!
