Dishwashers Logo
Wendy Foreman Posted on Mar 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher has bad odour and doesn't clean dishes properly I have cleaned filter and put cleaner through dishwasher but it doesn't take long for the odour to come back
Dalynn Turner
Level 2:
  • Expert 346 Answers
  • Posted on Mar 20, 2019
Dalynn Turner
Expert
Level 2:
Answers
346
Questions
Helped
169734
Points
755
Hi, do you have happen to have a garbage disposal? These are linked together and cause this type of odor. You might also need to change the filter if it is getting old. Running white vinegar through the dishwasher may be another option if the cleaner your using isn't working for very long. Good luck!
5 Related Answers
Anonymous
  • 94 Answers
  • Posted on Oct 21, 2007
SOURCE: GE GSD2200G02CC dishwasher
Your dishwasher probably has rotating blades on the top and bottom that spray water on the dishes.  Clean these off and make sure the holes are not clogged.
Anonymous
  • 3 Answers
  • Posted on Mar 04, 2008
SOURCE: Whirlpool Gold Dishwasher
Kerriann,
Did you get your Whirlpool dishwasher working. Mine quit cleaning so I took the lower spinner out, pulled the motor and pump assembly (very easy to do) then cleaned out the strainer which was full of glass and debris not allowing the water to recirculate. Works like new now. Cost....$0.00. Clean dishes...priceless.
Mike
  • 677 Answers
  • Posted on Apr 03, 2008
SOURCE: HElp Dishes not coming clean
www.dishwasherfilter.com has a great new product out that filters the water going into your dishwasher. it reduces minerals that cause that white build up or residue. it goes under the sink and doesnt take up much room at all. my dishes looked terrible until i put this filter in. it is very affordable and works great.
Anonymous
  • 1036 Answers
  • Posted on Jun 17, 2008
SOURCE: Not cleaning at all - most dishes end up being washed by hand afterwards
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
A
Anonymous
  • Posted on Jun 29, 2008
SOURCE: Dishwasher not cleaning dishes. Casade cleaner not disolved.???
KITCHEN AID DISHWASHER- SOAP REMAINS IN DISPENSER
Dishwasher smells
I would try a cleaning product such as dishwasher magic, as well I have been told that the crystals in the product Tang are excellent for cleaning and deodorizing, and of course it goes without saying that the cleaner your dishes go in, the cleaner your dishwasher will stay. Also, I would clean around the inside of the gasket located all around the tub but especially at the bottom where the main odours usually come from. Let me know what you find!
How do I get dishes cleaner?
Do not put bowls or cups in the bottom rack clean out the filter in the bottom of the washer
Dishwasher doesn't clean properly
Hi, have you cleaned filters out and then put a cleaner in and run it through ?
Sediment is collecting in the bottom and on the dishes. I have tried a cleaning cycle but it doesn't work.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
2answers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Foul odor coming from Miele dishwasher
hi,
if you put the unit on the hottest wash this will kill off the odour. after each wash leave the door open for about half an hour so it dries out and doesn't smell. Also make sure the filter is clean and the door seal is clean. this should all help with the odour
Just does not get dishes and GLASSES clean..so frustrating
If you are having hard water issues, there isn't much your dishwasher or dish soap/rinse aid can do about that--regardless of what some salesperson told you was installed into the machine. You either need a water softener or some type of filtration system established at whole home point of use.
The machine has suddenly stopped cleaning properly. I put a cleaner through every few weeks and the inside is clean. I have blown through the pipes and they seem to be ok. I have removed the arms and...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
3helpful
2answers
My dishwasher has left white chalky residue on all dishes and i have tried several times but it dosent go away
the problem is hard water. there is a product at www.dishwasherfilter.com that filters out these hard minerals that cause those spots and leaves your dishes crystal clear every time. it is very affordable and has a money back guarantee. you will love this product and your dishes again.
My dishwasher not cleaning properly
If your filter is dirty or "damaged beyond repair", dirt can be sent back to the dishes, glasses, flatware, etc.
Also, the water paths may have scale lining or blocking the pathways, which would reduce water pressure, prevent proper pressure, and / or block water spray.
The following link might give you some ideas... as for the filter, if you have the user's manual, the list of parts may be in the back with the index.
https://www.onegoodthingbyjillee.com/how-to-clean-your-dishwasher-in-3-easy-steps
Top Dishwashers Experts
Mike Cairns
Mike Cairns
