Seeburg SPS160 plays but won't let me make a selection? I hit numbers and keeps playing one right another
Won't quit playing after each record just pulls next record out in line and plays next number up
SOURCE:
SOURCE: I just bought this Seeburg
the reject switch on the mechanism is stuck or bad its right next to the tone arm
Posted on Aug 01, 2008
  • 306 Answers
SOURCE: 1968 ami rowe mm-2 juke box
the button may be repaired i suppose.. you need to replace with a new one else sontact a service center.. u stop pressing it and replace it.. if it goes on running it may create a master problem.. so first change the button!!
chek tis out http://tomszone.com/serialami.html
else
look out
http://www.gameroomantiques.com/Manual.htm#AMI-ROWEJUKEBOXES
Posted on Oct 17, 2008
Marcos_Ce
  • 71 Answers
SOURCE: Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Posted on Nov 24, 2008
MechMusicSF
  • 16 Answers
SOURCE: I have a 1971 seeburg firestar jukebox - the zero
Same key that operates the locks on the sides unlocks the top, but top might be sticky. Push down on it.
Order keys if you don't have them. It's key F291. GOOD locksmith can make it or order one off eBay.
Your jukebox is a USC2. Use that model number as a reference.
Keypad "0" contacts are probably dirty or broken, or the connectors to the keyboard or black and gray boxes might be loose or need cleaning. Circuit board might be dirty (YES! This is a common Seeburg issue). To clean it of check for broken contacts on the "0" key, you'll have to remove it and open it up. Putting it back together can be tricky. Be patient.
Worst case, you can install a replacement keyboard.
If you have someone come out, be SURE to have them give the jukebox a good lubrication. Seeburgs are complicated machines and need periodic lubrication.
Also, buy a manual. Jukebox repairmen don't usually have the manuals for your jukebox. Too many.
Posted on Apr 18, 2009
MechMusicSF
  • 16 Answers
SOURCE: Seeburg Stereo Phonograph Model ESL100 Q-65-H5
End of record switch out of adjustment or bad? Disconnected?
I have a 1963 Seeburg jukebox that won't play the b side of the records. How do I fix it?
Not likely you will get a good answer from the sewing machine category.
Feb 05, 2017 | Sewing Machines
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
Seeburg jukebox ay160 won't select record
(1) Make sure that the credit unit is not stuck and that all of the contacts open and close correctly while manually operating the solenoids. Lubricate it if the wheel does not turn freely. (2) Make sure that there are credits on the machine. (3) If it still wont select check fuses or (4) try pressing the letter and the number simultaneously, some "free play" set ups will work this way.
Jun 09, 2012 | Audio Players & Recorders
My Pioneer PDR 555-RW keeps reading Mon1 or Moni when I try to record my CD from my mixing board. I need to send this wedding music, and it is trapped in my board. HELP!
That's just a MONITOR indication. It means you can SEE the audio from the selected input on the record level meters for adjustment or other reasons. It won't prevent you from recording. Set your levels then hit RECORD, let it set itself up and calibrate to the disc, start your source and hit Play or Pause to start recording to the disc.
May 14, 2011 | Pioneer PD-R555RW CD Recorder
I have a LPC 480 Seeburg Jukebox that scans, pick up the record, the needle touches the record, then returns the record to the carriage without playing. What can I do?
Try reading this, basically the fault can be in the mech, the amp or trip switches.
http://www.flippers.com/Seeburg-trblshoot.html
Nov 28, 2010 | Audio Players & Recorders
Seeburg selectomatic 200 [has been stored in garage for 30 years ] all funtions work properly except it will only play record for about 1 second, then eject & go to next selected record & play for...
1. Check to see that the end of record switch is OK or not shorted, same with the reject button on the back and all associated connections.
2. THESE THINGS NEED OIL! The trip lever (just to the right of the tonearm) may not be resetting fast enough, or at all, due to gummy grease. Buy the manual (eBay - any service man will insist that you have it.). It will show you where to lubricate everything. NO 3-in-1 or paraffin based oils.
Oct 24, 2009 | Audio Players & Recorders
32 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
