When I lower the deck the further down it goes the less the blades spin until they stop. I have noticed the deck goes forward slightly as I lower it. The belt is new and ran correctly and the deck is attached correctly. What is causing said problem?
Your adjusting levers are not working properly. The front and back should be level. Make sure that the rear adjusters are not blocked by debris.
SOURCE: my 1979 111 john deere lawn tractor deck blades shut off
If it has a clutch, that would be the problem. An electric clutch will kick on and off when it is hot if it is bad.
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
SOURCE: The mower blades on my John Deere stx 38 lawn
it sounds like the safety switch under seat is bad
