SOURCE: can't get the remote to work
Try pressing the TV button on the Prima remote to make it work on the TV. It should work on the Prima Tv without new codes. Codes would be needed for your cable box.
Consider calling Prima at 866-447-7462 for the codes. They should have a website for the codes or email you the codes for free.
PS Please rate me if this helps.
SOURCE: PRIMA TV CODES
The 4-digit RCA code is 1238 if using an older RCA universal remote, or just 238 for the newer 3-digit ones.
SOURCE: I touch the on/off button on the Prima TV to turn
I am sure you had some strong static electricity. The static spark arced to inside of the TV in to the circuit board. Many of the low cost TV sets have poor static electricity protection.
In most cases there is damaged caused by static shock to electronic devices.
Just for curiosity, you can try unplugging the set from the AC mins and plugging it back in to do a simple reset, in case there is no damage and some logic device became hung up.
Last year I picked up my mobile phone and got a static shock from it. I had to get a new phone. This phone never worked again!
Jerry G.
Testimonial: "At least now I know what happened to it, thanks."
SOURCE: I am having problems programing a universal remote
urc-386-remote.blogspot com
URC-386 HRS-GLOBAL
URC-386 Universal Remote Control
http://urc-386-remote.blogspot.com
SOURCE: I need 3 digit code for my Prima tv to program bell express vu
Programming an Expressvu remote control can be frustrating. There are two basic ways of doing in it. The first one involves knowing both your TV brand name and also knowing the proper code to input in your remote. The second method is doing an automatic search. The following is a step by step procedure in how to program your dish network or Expressvu remote.
1)Make sure your TV and Satellite Receiver is ON.
2)Press and hold TV button until all lights on the side of it flashes. The TV button is the second button on the Top left hand side corner of the remote control.
3) Release that button, then press & release RED Button. You will notice TV button is stays on. If, it doesn't stay ON, you must repeat step 2 & 3. Otherwise, your batteries are low, you MUST change then.
4)Press and release the UP Arrow Key on the remote until TV turns off. Notice the UP arrow key button is the button below the volume keys (Stop button for VCR.)
5)Make sure you are aiming remote control to TV while pressing and releasing UP arrow key button. When you find the right code, the TV will turn OFF.
6) Immediately after, TV turns off, press # key.
