SOURCE: Door catch, handle, or mechanism broken
sorry but do not understand the question, if the **** has fallen off the door cannot be opened.
SOURCE: Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
SOURCE: broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
SOURCE: The door catch on my Hotpoint Aquarius WT540
You need to seperate the 2 halves of the door, remove all screws securing the 2 halves together, and prize apart.
You will then see how all the parts are fitted.
