Its just flashing and wont start a programme actually it doesnt even move
SOURCE: BEKO D 2731 FW Dishwasher Problem
possibly due to water in the sump tray. tilt machine back at 45deg and see if water runs out. if it does and you get rid of the water that way, then the machine should operate. if it reoccurs, then you have a leak
SOURCE: Zanussi Electrolux FX 1265 W washing machine wont work
Chrisbounty
also not ure what you meant by fused did you have some kind of electrical arcing sparking wires melting?
SOURCE: Frigidaire gallery series dishwasher wont start
the only other thing i know to tell you,without knowing more about this problem,is check the float switch in the tub(its under a tall cover,remove this cover & make sure it is'nt stuck in the up position)otherwise it could be anything from the water inlet solinoid,a bad switch,or even the pc board.hope this helps
SOURCE: flashing start light starts ok with prerinse programme then switches off having done nothing
Green light flashing
SOURCE: my iphone camera wont even start!
If jailbroken try use different .ipsw file. Or try Restore.
