The Elos cartridge is just gone to 50% and has been working perfectly fine up till now. I am a bit reluctant to use as do not know why this is happening or what it is. There are no error lights, it is coming on fine, shows the percentage of cartridge, sets the frequency fine and fires up ok aswell.
SOURCE: EasyCam Pro (HO98064)
Try a different driver if your not happy, remove cam and uninstall driver again through add/remove programmes. When you re connect use a different USB port if available. http://www.jascoproducts.com/cgi-local/SoftCart.exe/online-store/scstore/pro/computer_software_cams.html?L+scstore+gjlg2202ff442544 Sometimes the frequency needs to be set at 50HZ, the same as an Eye toy when it's used as a web cam, as the drivers are usually multi country.
SOURCE: DVD sound problem
Go into the setup menu into the audio options (use arrows on remote to go up and down menu and press left to enter the next menu to change options). By memory when I was running this just through a TV and not through a surround sound system, I had to turn off the addition speaker options in the audio menu. The one's like centre speaker etc have an small/large/off option. I had to turn these off so that all sound would come through the TV speaker only. That is about all I remember as I was trying to get this running for my aunt and I no longer have the DVD player.
SOURCE: colour cartridge
I had the same trouble with a rebuilt cart from Staples, try HP brand or Nukote brand. Nukote cost less and work great for me!
SOURCE: Epson R220 won't print
Nothing at all? Problem with micropiezo (micro pump) at head. But you said, replaced print head. So it might just lost electricity to head (problem with board).
SOURCE: Hi i have a HP 2133 mini notebook laptop and all
Does the laptop usully have a startup screen? (HP)
Replace your hard drive
